Scheduling a Configuration Backup
You also have the option to configure the controller to backup its configuration automatically based on a schedule you specify.
  1. Go to Administration > Backup and Restore.
  2. Select the Configuration tab.
  3. In Schedule Backup, you can configure the controller to backup its configuration automatically based on a schedule you specify.
    1. In Schedule Backup, click Enable.
    2. In Interval, set the schedule when the controller will automatically create a backup of its configuration. Options include: Daily, Weekly and Monthly.
    3. Hour: Select the hour of the day when the controller must generate the backup.
    4. Minute: Select the minute of the hour.
    5. Click OK.
You have completed configuring the controller to create a backup automatically.
