Configuring Access Points
You can configure an Access Point.
To configure an Access Point:
- From the list, select the Access Point that you want to configure and click Configure. The Edit AP page appears.
- Edit the parameters as explained in the table below.
- Click OK.
Select the
Override check box if you want to configure new settings.
| Field | Description | Your Action |
| AP Configuration > General Options | ||
| AP Name | Indicates the name of the AP. | Enter a name. |
| Description | Gives a short description of the AP. | Enter a short description. |
| Location | Indicates generic location. | Select the check box and enter the location. |
| Location Additional Information | Indicates specific location. | Select the check box and enter the location. |
| GPS Coordinates | Indicates the geographical location. | Select the option. For Manual option, enter the following details:
| User Location Information | Indicates the demographic information. | Enter the Area Code and Cell Identifier. |
| AP Admin Logon | Indicates the admin logon credentials. For the Default Zone, the SZ cluster name is used as the default logon ID and password. | Select the check box and enter the Logon ID and Password. |
| AP Configuration > Radio Options | ||
| Channel Range (2.4G) | Indicates that you want to override the 2.4GHz channel range that has been configured for the zone to which this AP group belong. | Select Select Channel Range (2.4G) check boxes for the channels on which you want the 2.4GHz radios of managed APs to operate. Channel options include channels 1 to 11. By default, all channels are selected. |
| Channel Range (5G) | Indicates that you want to override the 5GHz channel range that has been configured for the zone to which this AP group belong. | Select Select Channel Range (5G) check boxes for the channels on which you want the 5GHz radios of managed APs to operate. |
| Radio Options b/g/n (2.4 GHz) | Indicates the radio option 2.4 GHz configurations. | Select the following options:
| Radio Options a/n/ac (5 GHz) | Indicates the radio option 5 GHz configurations. | Select the following options:
| AP Configuration >
AP SNMP Options
NOTE For SCG200 controllers, AP SNMP Option is not supported.
| Override zone configuration | Allows you to override the existing zone configuration | Select the check box |
| Enable AP SNMP | Enables you to configure SNMP settings. | Select the check box |
| SNMPv2 Agent | Allows you to add users to SNMPv2 Agent. |
| SNMPv3 Agent | Allows you to add users to SNMPv3 Agent. |
| AP Configuration > Model Specific Options | ||
| Model Specific Control | Indicates that the model overides the AP settings. | Select the check box. |
| USB Port | Disables the USB port on the selected AP model. | Select the option. USB ports are enabled by default. |
| Status LEDs | Disable the status LED on the selected AP model. | Select the option. |
| LLDP | Enables the Link Layer Discovery Protocol (LLDP) on the selected AP model. | Select the option and enter the following details:
| PoE Operating Mode | Allows you to operate using PoE mode. | Select the option. |
| Port Settings | Indicates the port settings. | Select the option and choose the required LAN option. |
| AP Configuration > Advanced Options | ||
| Network Settings | Determines the network settings. | Select the IPv4 Settings from the following:
| Smart Monitor | Indicates AP interval check and retry threshold settings. | Select the required check boxes. |
| Syslog Options | Determines if external syslog server settings is applicable. | Select the required check boxes. For
Enable external syslog server option, update the following information:
| Hotspot 2.0 version Profile | Indicates the hotspot profile that you want to assign to the group. | Select the required option or click
Create and update the following details:
| AP Management VLAN | Indicates the AP management VLAN settings. | Select the check box and choose the option. |
| Auto Channel Selection | Indicates auto-channel settings. | Select the check box and choose the option. |
| Client Admission Control | Indicates the load thresholds on the AP at which it will stop accepting new clients. | Select the check boxes and update the following details:
| Swap Configuration | ||
| Add Swap-In AP | Allows to swap APs. | Select the check box and enter the Swap-in AP MAC details. |
You can also move the location of an AP or delete an AP. To do so, select the AP from the list and click
Move or
Delete as required.
