Creating a Tunnel DiffServ Profile
If you need to configure the type of traffic (ToS) bit settings for the access side traffic from Ruckus APs, follow these steps to create a Differentiated Services (DiffServ) profile. This profile can only be applied to Ruckus GRE and SoftGRE traffic.
  1. Go to Services & Profiles > Tunnels and Ports.
  2. Select the DiffServ tab, and then select the zone for which you want to create the profile.
  3. Click Create.
    The Create Tunnel DiffServ Profile page appears.
    Figure 105  Creating a Tunnel DiffServ Profile
  4. Configure the following:
    1. Name: Type a name for the DiffServ profile that you are creating.
    2. Description: Type a brief description for the DiffServ profile.
    3. Tunnel DiffServ: configure the following options.
      1. Set Uplink DiffServ: Select the check box if you want to set the Differentiated Services field for uplink user traffic from Ruckus APs towards either the controller or a third SmartCell Gateway 200/Virtual SmartZone High-Scale for Release 3.4.1 Administrator Guide 92 Managing Ruckus AP Zones Creating a DiffServ Profile party gateway via SoftGRE. Configure the desired value to be set by the Ruckus AP.
      2. Set Downlink DiffServ: Select the check box if you want to set the Differentiated Services field for downlink user traffic from the controller towards the AP, and then configure the desired value to be set by the Ruckus AP.
    4. Preserved DiffServ: Configure up to eight (8) entries in the preserved DiffServ list. The Preserved DiffServ list allows the preservation of values that have been already marked in incoming packets either in uplink or downlink traffic.
    5. Click OK.
You have created the DiffServ profile.
You can also edit, clone and delete the profile by selecting the options Configure, Clone and Delete respectively, from the DiffServ tab.
