Applying a WLAN Template
You can apply only WLAN-related configuration to an AP zone using a WLAN template.
Follow these steps to apply a WLAN template:
  1. From the Wireless LANs page, locate the zone where you want to apply the WLAN template.
  2. Click More and select Apply WLAN Template, the Apply WLAN Template dialog box appears.
  3. From the Select a WLAN template drop-down, select the template.
  4. Click OK, a confirmation message appears asking to apply the wlan templates to the zone.
  5. Click Yes, a confirmation message appears stating the template was applied successfully.
    You have completed applying WLAN template to the AP zone.
