Viewing Statistics for SoftGRE IPsec Tunnels
The web interface displays the table and its corresponding graph chart. The two representations are synchronized and controlled by the search criteria. For performance reasons, total counters per DP or per AP for each bin may be pre-calculated.
To view the SoftGRE IPsec Tunnel Statistics:
  1. From the left pane, select Report > Ruckus AP Tunnel Stats. The Ruckus GRE tab appears by default.
  2. Select SoftGRE + IPsec. Update the parameters as explained in the table below.
  3. Click:
    • Load Data— To view the report in the workspace.
    • Export CSV—To open or save the report in CSV file format.
Table 44 SoftGRE + IPsec Report Parameters
Field Description Your Action
Time Period Indicate the time period for which you want to view the report. Move the slider to set the duration.
Zone Name Specifies the zone for which you want to view the report. Select the required zone.
Gateway Address Specifies the gateway address Enter the gateway address.
AP MAC or IP Address Indicates the MAC of the Access Point or IP Address. Enter the AP MAC or IP address.
The table below contains the report based on the statistics for access point IPsec. Each entry contains the 15 minutes cumulative data.
Table 45 SoftGRE + IPsecReport Attributes
Attribute Type Description
Time Long Bin ID, which is stamped at a 15 minute interval. For example, 10:00, 10:15.
TXBytes Long Indicates the number of bytes sent.
RXBytes Long Indicates the number of bytes received.
TXPkts Long Indicates the number of packets sent.
RXPkts Long Indicates the number of packets received.
TX Dropped Packets Long Indicates the number of packets dropped.
RX Dropped Packets Long Indicates the number of packets dropped.
