Configuring License Bandwidth
You can assign a license bandwidth for a virtual data plane provided it is already approved. Each virtual data plane can be configured with only one bandwidth license.
  1. Go to Administration > Licenses.
  2. Select the License Bandwidth Configuration tab.
    The License Bandwidth Configuration page appears.
    Figure 142  License Bandwidth Configuration
  3. In vSZ-D, type the name of the virtual data plane.
  4. From the Bandwidth drop-down menu, select the license bandwidth you want to assign to the virtual data plane. Default is 1 Gbps.
  5. Click Add. The vSZ-D with the assigned license bandwidth is displayed.
  6. Click OK.
    The message Submitting form appears, and the vSZ-D is assigned a bandwidth.
You have successfully assigned a license bandwidth to the virtual data plane.
