Backing up and Restoring ICX Switch Configuration
SmartZone can back up the switch's running configuration. By default, SmartZone makes a backup of switch configuration on a daily basis. When needed, these backups can be restored to the switch. While performing network maintenance, you can initiate a backup without having to wait for the daily backup.
Perform the following steps to configure ICX switch backups.
Be sure to sync the controller to the NTP server during installation. You can also do this from
